QuincyDowling09
Hi Folks,
I am at wits end with this strange situation. I apologize for the long post but I wanted to give some history on this. Any help or guidance would be the best Christmas present ever.
Water Issue:
1. House pipes are copper
2. Submerged Well pump outside (pump is ½ hp Aermotor)
3. Well-X-Trol water storage tank
4. Aquabubble water softener
5. AIRaider Water Radon System
6. Countyline water storage tank (pump is ½ hp Pentair)
When did Problem Start
Water Issue:
- When I run water bypassing radon thus not using storage tank used to hold water after radon is taken out the water is crystal clear.
- When water runs through the radon system I see yellow and orange rusty water coming into the system.
- The water in AIRadar tank that supplies water to storage tank is crystal clear on all occasions.
- Note: Rusty water will come out for a minute or two then clear.
- 12/3/15 – Original Motor on water tank after Radon System died and was replaced
- Within a couple months noticed rusty color water in back of toilet (yellow water to start then orange toilet). Did not think much of it at the time. Cleaned toilets but it kept coming back.
- 5/31/15 – Replaced 12 + year old Hot water heater thinking rust could be there but rusty water still occurred
- 8/13/15 – Replaced old water storage tank after the radon system. It was old so thought it might have broken bladder causing water to rust. Rusty water continues
- 10/7/16 – Had Water Service company test to water samples:
- Water directly from well bypassing softener and radon (no iron was detected, 2.87 magnesium)
- Water after it was treated by softener and radon (.04 iron was detected, .04 magnesium)
- Note: I believe water sample taken after radon system was not when water first turned on. I think the guy let faucet run for a bit before taking sample therefore iron or bacteria might have been flushed.
- 11/25/16 – Cleaned all toilets and ran water bypassing radon system for 3 weeks and water is crystal clear.
- 11/25/16 – Noticed hose connecting radon system and pump on to top of storage tank had rust on it and there was little water droplets. It looks like seal was not tight letting air in.
- The poor connection of hose to pump let air into pump and corroded the new motor put in on 12/3/15. That poor connection was that way for over 1 year.
- Rusted pump and possibly Iron Bacteria
- Had radon guy come and take pump off to examine. It was rusty with some red slime on inside.
- He installed a new pumped and cleaned fittings that had red on it with bleach water and re-assembled.
- We believed the root cause was now fixed since tight hose connection and new pump.
- Water coming from water tank after Radon system is again yellow with bursts of orange. After 2 minutes it appears to clear.
- Water in AirRaider before storage tank is still crystal clear.
- Do you think the supply hose from radon tank to pump and the new storage tank are corroded with iron bacteria?
- If so how would I remediate it? Do I need to replace the tank, hoses, fittings, etc…?
- I am in central Massachusetts. Any idea who I need to call next? Plumber, water specialist, etc....
- I don’t understand how the water in the AIRaider is crystal clear and when it gets in storage tank in gets contaminated.
- I have added bleach to AIRaider tank to feed bleach into storage tank. Let sit for 4 hrs then I drain tank and always get rusty water. I have done this 3 separate times in an attempt to flush tank and hoses.
