That's a good kit; some kits, even if it has brass bolts, may have steel nuts and washersThis is the kind of heavy-duty quality product I think you are looking for
http://www.lasco.net/tank-bolts-c-2937_323_373/38-brass-close-coupled-bolts-p-6234.html#.V7KH8pgrKUk
This set has, for each bolt, two rubber washers, too brass nuts and two brass washers. This allows you to double nut the tank installation. Rubber washer and bolt head inside the tank, metal washer and one nut outside the tank, then rubber washer, metal washer and other nut under the bowl.
I used plastic bolts on my install. With these bolts, and caulking around the base, its not going to move.
http://www.supplyhouse.com/Sioux-Chief-425-PB-2-1-2-Closet-Bolts-Bag-of-2
hmmm interesting; plastic bolts! Those would never have rust issues and are likely to be easily unscrewed, but can be easily cut if necessary.I used plastic bolts on my install. With these bolts, and caulking around the base, its not going to move.
EDIT - I thought OP was looking for non-rusting mounting bolts, but I see in other replies, pictures of Tank to Bowl mounting bolts. So I guess I misunderstood.
