Curtis Brown
I have a Rusco 1.5" filter with a 100 mesh poly screen. It filters my well water before my WaterFurnace geothermal system, so quite a bit of water moves through it. I generally flush once every 2-3 days. When I flush it, the particles on the filter generally don't seem to flush off, and so I have to take it out and manually clean it every week. Would I have more luck getting it clean with a stainless steel screen, or another mesh size? The particles seem to be relatively fine sand.
Some other info. I have not noticed a restriction or water flow issue with my geothermal unit, so the particles clinging don't seem to affect water flow, at least not quickly. Also, my pump puts out 10 gpm, so I also wonder if the 1" filter would be more appropriate for my situation. Maybe I have a flow issue that's causing the filter to not flush correctly.
Also, I've considered an automatic flush valve, but if the flush isn't actually doing its job and I will still have to manually clean the filter, seems a waste of money. Any suggestions would be appreciated.
