Nukedaddy
There are several makers of switch and junction boxes using PVC or other resins acceptable to code. The code requires the romex to be restrained by a staple or ? Within a few inches of the box. OK so far?
Some brands are obvious how to get the romex into the box as they have a simple rectangular knockout to remove completely. BUT: What about the others? Some have what appears to be a resilient clamp that still must be cut or pried open that seems to be intended to clamp/restrain the romex where it enters the box. Some have what may be a 2 part knockout, but is angled inward the box and may have some clamping function.
What is common to most or all the brands is a complete lack of instructions or any guidance on what is the intended method. Cut it out, bend it in or stare at it in grief. It would make a preacher cuss on Christmas!
All these boxes are sold the same way, in bulk or singly in bins at big box lumberyards with no directions.
Has anyone seen and can share the maker’s “right” way to work the clamping types? Maybe share a link to a brand video? Like I said earlier, the ones that are clearly intended to cut/knock out are not an issue. Only the devilishly designed clamp-like critters vex me. I think some are Thomas & Betts, some Carlon, some Others.
Also. If the thingies are cable clamps, and installed correctly, does the code credit them as cable restraint and remove the need for a staple nearby?
