Good morning,
My current surface pump pressure switch is set 35-50
The pump is 100ft from the house then it has to push the water through a softener & an iron filter. By the time water gets inside the house the pressure is pretty low
I raise it to 60 then the pump keeps running unless I drop it back down to 50
Is there any way to raise my pressure to 40-60 without buying new equipment?
If I could get the cut in pressure raised to 40 I think that would make at least a noticeable difference
thank you
thank you
