Greeting all.
Have a Riello F5 for a while, love it. Back when it was on a single line system, I could check/dial in the pump pressure and the gauge read and responded to what I would set without much gauge fluctuation. The gauge remained steady at whatever pressure, both pre and post purge.
We have changed to a 2 line system with our new oil tank, and when I check the pump pressure, the gauge fluctuates quickly (actually looks like fast fluttering) within a 20psi range. I can adjust the pressure, but it is not as responsive as I recall with the single line system, and as I turn it up, it does revert back (lower) a bit with each increase, and seems not to want to go higher than 160psi. (I didn't want to push it either)
Question: Is this normal for a 2 line system with Riello or is the pump malfunctioning?
This is not a Tigerloop, just a return to the tank. The burner is working without issues.
Thanks in advance for any insight on this.
