Rheem sacrificial anode that doesn't "sacrifice" itself?
x-ray
Vancouver, Canada
Our Rheem hot water tank was installed in 2019 so I considered this to be time to replace the anode rod. I was astounded to see that the anode rod had not sacrificed itself at all. Being a simple, passive (non-powered) rod, it seems obvious to me that this means it is entirely ineffective. I left the old installed and decided to research this matter.
what's going on?
I don't know the type of material it contains. since I purchased a replacement (Mg) from Rheem, it calls into question the value of an anode rod from Rheem.
is there some sort of coating that needs to be sanded off? I think that would be a good starting point.
I'm planning to cut off a piece of the new one and see if it burns like Mg...
The next time you pull the rod, check for continuity from the metal rod to the threads. Some anode rods have a resistor in line, and maybe the resistor or a connection failed. I have read that the anode rods with a resistor have a bump on top.
https://patents.google.com/patent/WO2006060024A1/en for a different anode says "The resistance can be in the range of about 5 ohms to about 500 ohms. The resistance also can be in the range of about 30 ohms to about 60 ohms."
x-ray
Vancouver, Canada
hmmm, interesting. I shall check that. Thank you!!!
