Johnny-Canuck
I'm redoing a small bathroom floor surface and am installing a new "comfort height" toilet in prep for my 90 year Mom's return to her house after suffering a fractured hip.
Everything was going fine till I got to the point of unpacking the toilet and thinking I'd be able to install it this afternoon. But when I looked closely at the toilet flange, I now see that the plumber that must have originally installed the flange in the house back in 1963 when it was built, screwed up the alignment of the flange, so that the 2 cut out areas that are meant to allow you to insert the 2 flat headed closet bolts into the flange are exactly at the 9 oclock and 3 oclock orientation which is the worst possible location, in terms of expecting to get the most solid connection between the toilet bowl and the flange. These openings really should be at something like 11 oclock and 5 oclock.
I've attached a picture to show what I mean
I need a quick / simple (and even a "dirty") solution that anyone can suggest to get a more solid way to connect the toilet bowl to the flange.
(e.g. is their a refit flange I can get? could I just use bolts that screw into the floor (no way to adjust the position of the bowl); etc.)
All ideas welcome and much appreciated.
PS: another more minor issue is the fact that the very top plange of the flange is ~1/8" below the level of the new vinyl tile. I'm not sure what the "official" / "proper" answer is. (Should the flange sit on top of the finished floor or be level with it). Anyway, to correct for this also being a potential problem I've decided to use a "jumbo" wax ring rather than the standard thickness ring that came with the American Standard toilet. Is my thinking reasonable?
Thanks alot. John
Thanks alot. John
