I’m in Michigan and my city adheres to the 2015 IPC code.
Next item on the list of things to repair are some large notches/holes run through an exterior load bearing wall from an original copper drain that was in place. (see pic).
This is a laundry room and I am putting all new drains for a laundry tub on left and washer standpipe on the right.
My intent was to set it up as follows (see dry fit pic):
- Offset the drain out of the load bearing wall using two short 90’s
- 2” double fixture fitting
- Clean-out directly above the double fixture
- 2” vent straight out the roof.
My main concern is the short sweep 90’s. Any issue here? I’m trying to keep the drain trap low to support a deep laundry tub so that’s driving the short 90’s. Anything else I’m not considering?
Thanks to the continual support from this group!
