Hi all,
I'm about to replace a couple of old failing water heaters and I wanted to double-check that my design is sound. The current system works but I believe it's not plumbed correctly. Each water heater feeds a separate floor and each has recirculation return line. The return lines are merged and fed by a single recirc. pump. There are no check valves on the cold lines, so we frequently get warm water from cold side of sinks. There is only one expansion tank and it is flooded.
Here's the new design. I realize that ideally I would add another recirc. pump, but I'd like to keep using the current single setup for now to save some $$. I'm adding two new expansion tanks and moving the ball valves before the expansion tanks (instead of after). Also adding check valves and plumbing the return to the cold line instead of drain. Please let me know if this will work.
