Taylorjm
Active Member
So I built my own RO filter setup with a vane pump and 400gpd membrane. Out of simplicity sake, I'm using a vane pump and an 80/100psi pressure switch to a 400gpd membrane and out to a small RO storage tank and a 40/60psi pressure switch on the output. I get about 5 gallons drawdown at 12psi and it feeds a refrigerator and side faucet on the kitchen sink with 1/4" id pex line. It takes about 30 min to fill the storage tank when empty, and the pump kicks on after using maybe a gallon of water when the tank drops to 40psi. I'm good with the water production rate, but wondered about the storage tank psi. I know ro tanks are usually low, 7-10psi range, but they are usually also low output pressure because they don't normally have a high incoming pressure. I tried setting the tank at 38 psi like a well bladder tank, but then my drawdown is much lower. I also have another smaller, maybe 3 gallon ro tank that I could put in series to give me some more storage, or I also have a leftover 20 gal well pressure tank that's in great shape because I just upgraded mine to a larger one. The 20 gal well pressure tank only has about 5 gal drawdown at 38 psi, so not sure what that would gain me since I now have 5 gal drawdown at 12psi. Since it's only going through a 1/4" pex line, I don't know if the higher pressure in the tank is needed. So what should my storage tank pressure be?
