I have a GE Profile Model PXRQ15RBL reverse osmosis system. I would like to add a permeate pump. There are 4 connection points on the manifold: 1. Outlet (Blue) which goes from manifold to fridge, 2. Tank (Red) which goes to the water tank, 3. Drain (Black) which goes to drain, 4. Inlet (yellow) which is the supply from the saddle valve.
I believe the following are the correct connections when adding a permeate pump, but I would appreciate someone confirming I'm correct or setting me straight.
1. Outlet from manifold to Permeate In, 2. Permeate Out to a "T" which splits to the Tank and Fridge, 3. Tank (Leave Open), 4. Drain from manifold to Brine In on permeate pump, 4. Brine Out to drain.
I'm not sure if leaving the "Tank" port on the r/o manifold open is correct.
Thank you in advance for the help!
