Mittenstate
I am trying to reseat a drain flange in a fiberglass tub with PVC pipes. I replaced two gaskets with a standard gasket purchased from Home Depot, slipping it between the tub and the drain shoe. I used plumbers putty around the underside of the drain flange. I cleaned the threads on the flange before replacing it.
After running the tub, it is leaking a small amount of water on the ceiling below. Unfortunately there is not an entry point to see the location of the leak.
One oddity is that the drain flange refuses to seat flatly and instead tilts towards one direction slightly.
Do you have any recommendations for troubleshooting?
