Steven Gregory
Steven
Our washer drains into our downstairs utility sink bowl and the other day it got clogged up. I tried running some Drano and hot water down it to see if it would fix the problem, it didn't. I couldn't really get a snake down into the drain so I decided to try and take the pipes off underneath. I ended up breaking them in the process of trying to get them apart. I'm currently stuck trying to get the galzanized drain pipe unthreaded from the cast iron that comes out of the basement floor. After I get it apart I would like to replace with PVC and hook up the washer so it drains right to the drain pipe and not into the sink bowl. Any tips on how to get them loose? I've already tried pb blaster and applying heat.
