Otto Thorsen
Howdy,
I am a facilities manager and I am replacing a cheap Home Depot pump with a Zoeller. The guys that did the install used a plastic trash can as a basin and there are two 4" pipes draining into it. This is a pretty old part of the building with brick walls and a concrete floor. The concrete floor is only about 4" deep. The dirt (pretty sandy in texture) under the concrete is starting to push the walls of the "basin" inward and there is not enough room for the new pump to sit. I would like to install a hard shell basin but I'm not sure how to navigate those pipes. Will I need to cut them and connect a segment of pipe? Any thoughts?
