Watson524
Hi all,
Went up to visit my 83 year old godmother today and happened to be there while her grandson was in the shower and while someone was in the basement cleaning out, I hear them yelling my name to come look at water coming out of the ceiling into the unfinished basement. Turns out the shower drain is leaking right up at the top so I assume the compression gasket that's in there has $hit the bed after almost 30 years since the house was built. Since I have clear access to the whole underneath, is it recommended to replace the entire thing down to the P trap? Or just a topside replacement? I didn't get to remove the floor drain cover and see what's what in there but I assume it's your standard 2" drain with the notched compression nut that uses the tool you don't want to end up in the drain. I've only ever seen these from the top and never much thought about how the lower part connects to the tail pipe.
Also have a potential issue with her washing machine water lines but that'll be another post
thanks!
thanks!
