John Prinos
So is there enough movement to get the hubs to 5-3/4" apart? If so, you can just glue up both joints at the same time with a 5-3/4" pipe segment. Mark your pipe to be be sure it's centered in available 6-1/4", rather than 1" in one hub and only 1/2" into the other hub.
Since the old joint leaked, it would be nice to get a longer pipe segment in there than just 5-1/4".
If you can't get enough movement, you may have to just replace a greater length of pipe, so you have more maneuverability.
Cheers, Wayne
So the tighter fit should hopefully mean a lower chance of leaking. My only worry is the large chance I won’t have time (or possibly strength) to twist it before the glue holds.
Thanks Wayne, I’ll play with the dry fit and will see.
