No. You do have to set the air precharge to match your pressure. With a submersible pump, set that to 2 psi below the cut-on pressure.
The pump will be empty on the water side of the diaphragm before water pressure is applied.
The old failed tank may have water trapped on the air side of the diaphragm, so the tank will be heavy. You may drill some big holes to let the trapped water out to make it lighter.
If that is a Pentair WellMate pressure tank, those have a bladder instead of a diaphragm, and they are more likely to fail sooner. The bladders in theory are replaceable, but that seldom happens. Pentair WellMate tanks are good for other purposes, but not so durable as pressure tanks.
You might be able to remove the bladder from up top. Then suck water out of the tank with a wet-dry vacuum or a suction pump. I have never done it.
Normally you put a drain valve low at the tank entrance. That lets you clean out sediment periodically, maybe annually.
