The galvanized fitting thats on the supply line from the well needs replacing.Looking over options I see there are brass and plastic (dark gray)types that look identical.Whats my best option?Id also like to know if using pvc to replace the galvanized pipes is ok.I plan on replacing the pressure gauge and relay at the same time.It all looks possible with all the parts available in pvc .Also should there be a check valve between the well supply and tank? thanks so much.
