Replacing Pedestal Sink with Vanity
RMO194
Kansas City
Big difference. IPC. https://www.ci.independence.mo.us/userdocs/ComDev/2018 INTL PLUMBING CODE.pdf
https://westernrooter.com/plumbing-glossary/ is a good list.
FIP is the same as FNPT (female National Pipe Taper). MIP is Male. On Supply house they might just say M and F in descriptions.
You're awesome, Reach4. Knowing that I am in a IPC location, does your original recommendation stand (those links to the Home Depot parts)?
I take it that others began listing other parts was due to thinking that I was under UPC codes??
Yes, but only as a solution-- an inexpensive solution.
The other solutions are good too. A 45 elbow may be a more elegant solution.
RMO194
Kansas City
A 45 elbow, like that Durham one that Jeff H Young suggested? To me, it doesn't make sense to mix iron and plastic. Am I missing something?
wwhitney
Berkeley, CA
As you have a tubular connection at the wall, the tubular solution Reach4 proposed is fine, since you live in a suburb of Kansas City (and are subject to the IPC), rather than in Kansas City proper (which would apparently mean you are subject to the UPC). The only possible hiccup I foresee is if you want to maintain that escutcheon at the wall, the tubular 45 may end up far enough away from the wall that the trap geometry is difficult. Also if the current escutcheon is for 1-1/4" tubular, you'd need a 1-1/2" tubular escutcheon.
Another possible tubular solution would be to take the offset Reach4 pointed to, cut it into two 45 degree SJ x spigot sections, and use them to offset the tailpiece. [Sorry if this was already mentioned and I missed it.] That would obviously require a 1-1/2" tubular trap, with the 1-1/4" x 1-1/2" transition taking place at the upstream most SJ connection. Or else finding a 1-1/4" version of the double 45 SJ offset.
Depending on what exactly is behind the escutcheon at the wall, a non-tubular solution might be more elegant, but not really otherwise better.
Cheers, Wayne
RMO194
Kansas City
Thanks again. Assuming I go with the slip joint (and not an elbow) at the wall, do I need to get a Trap Adapter, or does the Reducing Washer serve that purpose? Also, should I need any additional PVC pipe--or should I have all that I need with the Offset Trap and P-Trap?
wwhitney
Berkeley, CA
The photo you posted, behind the escutcheon there should be a slip joint connection. I'm pretty confident the tailpiece on the sink is 1-1/4" OD tubular. Not as sure about the trap and the piece sticking out of the wall. I see 3 possibilities:
1) The pipe sticking out of the wall is 1-1/2" OD tubular. Then you have a 1-1/2" SJ connection behind the escutcheon. You can use Reach4's suggestion. You'll need a 1-1/4" x 1-1/2" reducing slip joint washer at the place where you want to connect a 1-1/4" OD tube to a 1-1/2" SJ connection. That could be the trap inlet if you use a 1-1/2" tubular trap, or it could be at the 45 degree elbow inlet if you use a 1-1/4" tubular trap.
2) The pipe sticking out of the wall is 1-1/4" OD tubular, but the SJ connection behind the escutcheon is a 1-1/2" SJ connection with a reducing washer. Your options are the same as in (1) above.
3) The pipe sticking out of the wall is 1-1/4" OD tubular, and the SJ connection behind the escutcheon is a 1-1/4" SJ connection. [The DWV pipe in the wall has a 1-1/4" trap adapter installed on it.] Then for a totally tubular solution, you'd need to find a 1-1/4" 45 degree tubular elbow, and you'd use a 1-1/4" tubular trap, and no reducing washers.
Cheers, Wayne
If there is a problem, it's not with mixing iron and plastic. Iron+iron is not better.
Now maybe malleable iron rusts slowly and would be good for 100 years. I don't know.
PVC? Or do you mean the new white drain plastic which is polypropylene, or are you implying that the threads already coming out the wall are pvc?
RMO194
Kansas City
I removed the chrome piece that was in the wall (see photo to follow). The wall opening is 1-1/2, and the chrome piece is 1-1/4. You can see the reducing washer on it.
That sure seems different than what I thought I saw in this photo:
So now are you going to need to find 1-1/4 inch double offset to make a slip joint 45? Here is one in chrome"
It's a little harder to cut than plastic, but not bad. I would think cutoff wheel in an angle grinder if I had one, or a very fine blade hacksaw.
RMO194
Kansas City
I will be using PVC, not chrome. Chrome is just what the pedestal sink used. With the new vanity, all plumbing will be enclosed in the cabinet. All other bathroom sink plumbing in the house uses PVC.
wwhitney
Berkeley, CA
I don't see why. The OP says there was a reducing washer, so it's a 1-1/2" trap adapter, and can accept a 1-1/2" tubular pipe with 45 degree bend.
BTW, another option is to use a a 1-1/2" trap along with a Pasco "Freedom Arm".
Cheers, Wayne
RMO194
Kansas City
So no problem mixing the chrome with plastic tubing? Sorry, I may have used the wrong terminology earlier. By 'PVC,' I meant white plastic (or as I have learned--polypropylene). Thanks again, guys!
John Gayewski
Iowa
Almost all chrome trap assemblies drain into plastic nowadays. So no, no problem.
RMO194
Kansas City
Is this the 45 elbow I need?
If so, is this the adapter I would then need?
