TunaBreath
The sewage stack at my parent's house is 3" copper and has been replaced in pieces due to sections becoming thin and developing pinhole leaks. I snaked a bore-scope camera through the cleanout (in the photo below, the camera lens is looking back up through the sewage stack, you can see the clay pipe in the right of photo) and it seems that the sewage stack is copper right to the cement floor and then it is inserted into clay pipe? How is the copper connected to the clay? from the photo it seems that it is just a "press fit" as I see no lip from the copper. Any ideas how to go about replacing? Right now I am wondering if I can just basically cut the copper above the floor and then possibly "peel" out the thin copper from the clay. Would be replacing with PVC but as far as connecting the PVC to the clay, I am wondering if it could be a press fit (with added silicone) or if I would have to break up the concrete floor around it and use some type of coupling. Any help or guidance is appreciated.
