Replacing closet flange - damaged drain pipe
MC922
Vero Beach, FL
I am renovating a bathroom in my home. I decided to replace the old flange with a new one (first mistake). the old flange was 3" pvc solvent welded into the 4" drain pipe. removing the old flange was a nightmare and in the process I wound up breaking the top of the drain pipe in several places (see images below). I am hoping that I did not create a much larger problem and bigger expense by doing this. The damage goes about 2 or 3 inches into the drain pipe. How can I fix this? I was thinking a flange with a longer pipe to go into the drain far enough to cover the damages area, possibly a coupling....no clue what to do here.
any suggestions and help is greatly appreciated!
It looks like you have an inside mounted flange, so the ID of the top part of what's left of the old flange is neither 3" or 4" (probably 3.5"). You could use a tool called a RamBit to ream out the existing pipe down to the hub of the elbow that is below, glue a new riser in place, then add a new flange. You'd have to cut the pipe low enough to cut out at least the thickness of what's left of the old flange since the RamBit is designed to use the inside of the pipe as a guide. AN inside pipe cutter (looks like a small circular saw on a shaft you use with a drill) could cut it off. Make sure to stuff something into the pipe to prevent clogging it up with plastic pieces or chunks.
Cacher_Chick
Test, Don't Guess!
If you have access from below, it may be a simple matter to replace the closet elbow, riser, and flange with standard materials.
Will Rogers Plumbing
Plumbing Contractor
Bixby, Ok
www.willrogersplumbing.com
Use a inside the pipe cutter to cut pipe square. Looks like you have foam around your 4" PVC riser. Remove enough foam to glue a coupling 4" with new 4" PVC riser to match correct height for new flange. Use a 4"/3" flange. It will glue inside of 4" PVC pipe or over 3" PVC pipe. Make sure to anchor flange to slab. If you don't have enough concrete to anchor to, there is a product called Rockite that will allow to be drilled in 20-30 min.
