69velle
Hello all
I have a shower with a cast iron P-trap that is leaking. At first i was hoping to cut out the old trap and splice a new abs one in with a rubber coupling, but the trap arm is not long enough to have a nice square cut with enough material for a coupling. I might get 1" of usable straight pipe by cutting it. Will a Fernco donut work in a cast Tee hub? What other methods do you recommend to get the old pipe out and install ABS? Based on the picture does this look like an oakum/lead or something else to drill out?
Ignore the current coupling as that is old.
Thank you
Thank you
