Replacing Case 3000 Wall Mount Toilet with American Standard Glenwall VorMaX
Kay C
We are doing a total remodel of a bathroom and replacing a 1960's era Case 3000 wall mounted toilet. We undertand that the 2-bolt carrier for the old Case toilet won't work on any new wall mount toilet. We're considering an American Standard Glenwall VorMax but can't find a replacement wall carrier system. What would you recommend? Is this the best choice of a new wall mount toilet? The toilet is under a window so we don't have the wall space for the newer type of wall mounted toilet that requires the in-wall tank.
index.php
Have you opened up the wall behind? Often the carrier in back has places for four bolts and only the top two were used.
index.php
Case 3000 wallhung
Kay C
We have a blue one like that. We haven't opened the wall yet, so I don't know. If we do need to replace the carrier, do you have a recommendation and a supplier?
Marlinman
Jacksonville Florida
This is from HJ on a earlier post.
There is no direct replacement for the Case/Briggs 3000. To replace it you have to remove the bracket mount and revise the carrier by installing the two top bolts and then using a conventional wall mount.
Norwood451
san luis Obispo
I Terry. My case 3000 toilet needs replacing. Is there a similar 2 bolt toilet or can we use a 4 bolt wall mount instead. If so, can you recommend the best choice to replace the case 3000?
