Ben E
My home has a UP 15-18B5 recirculating pump on domestic hot water. Original to home (2003). Dedicated return line.
Pump chamber is soldered to copper pipes. Annoying -- best practice is flanges -- but I am not the original builder, so this is what I'm working with.
Pump has failed. I need to replace it.
First idea is a direct replacement with same model. Shut off water using valves before and after the pump, disconnect electricity, loosen the four allen screws holding the pump motor onto the chamber, remove and discard current pump motor, install new motor, tighten screws, open valves, reconnect electricity. Workable? Then no need to solder.
Suppose I wanted to substitute a more modern replacement with efficient motor. The Grunfos Alpha and Alpha2 series look promising, and cost difference is not so much. From online photos, the alignment of the four allen screws looks like it could be the same, though I can't tell if the screw placement is really the same, if the seal is the same, if the existing pump chamber could be used with the Alpha/Alpha2 pump motor. Anyone know? Any concern using a stainless steel Alpha pump with the existing brass chamber? Other suggestions for a drop-in replacement?
