I am replacing a washer in the lowest level of a quad level home.
The drain the current washer runs to is 36" above the floor that the washer sits on. (The washer sits against the north wall and drains into a drain under a bathtub on the west wall–which is a 36" high concrete shelf that is the next level of the home.)
The current (very old) washer drain hose goes 42" almost straight up to a copper pipe, which runs west for 14", takes 90 degree elbow, travels 33" south, hits a 45 degree bend (to curve around a stud), travels 3" and then takes a 90 degree elbow downward into a 2" drain pipe that leads under the concrete foundation of the home into the main sewer line.
Obviously, I don't want to hook a new washer up to that setup for a number of reasons...
I am trying to figure out if there is a legit way to go from the new washer (which will sit on a pedestal) to the drain that is 36" higher than the floor that the washer sits on. (I could run the washer's hose to a utility sink and then to the sump, but since I have access to a drain, I'd like to avoid that, if at all possible.)
I am including sketches of the current setup and my working sketch of the future setup.
Regarding the future setup:
- The run will be 2" PVC from the standpipe all the way to the drain.
- There's no vent available without major changes...that may happen later, but I'm leaning toward an AAV for now. (They are allowed here.)
Questions
- Can the standpipe end 60" from the floor...if that is only 24" above the drain?
- Can the p-trap sit 38" above the floor if that is 2" above the drain?
- How much horizontal pipe can I run between the p-trap and the drain? (I could add significant slope to it.)
Thanks for any help you can offer with this maybe crazy setup!
Questions
