A hole in the drop pipe or the pitless leaking will usually let air into the system. Leaking back but no air from the faucets usually means a bad check valve.
Received the CSV1A today; will install it next weekend. I won't be using the two threaded ports currently filled with PVC plugs. Do I need to get brass plugs to fill these ports long term or will the PVC plugs be sufficient? Thank you.A hole in the drop pipe or the pitless leaking will usually let air into the system. Leaking back but no air from the faucets usually means a bad check valve.
PVC plugs are good as they will handle more pressure than anything will ever see.Received the CSV1A today; will install it next weekend. I won't be using the two threaded ports currently filled with PVC plugs. Do I need to get brass plugs to fill these ports long term or will the PVC plugs be sufficient? Thank you.
Thank you all!PVC plugs are good as they will handle more pressure than anything will ever see.
Thank you and hope you enjoy the CSV for many years. But cycling every 10 minutes is 144 times a day. I would plan of fixing that leak as soon as possible. In the meantime, install another check valve before the CSV and tank. The extra check valve will cause some water hammer on pump start, and maybe some air in the lines, but the pump won't cycle every 10 minutes. You can move the check valve to the pump when you get the leak fixed.Closing the loop on this project. Well guy came up and checked both the check valve and the pitless -- both were OK. He tells me: a) the periodic cycling due to loss of pressure is due to a pinhole leak somewhere between the pump and the house; b) the periodic cycling (takes about 10 minutes for pressure to drop from 60 to 40 psi, even with no water use) is not going to hurt the pump; c) when the cycling gets down to a minute or two, it will be time to dig and fix the pinhole leak; and d) he did not laugh at my DIY water system (with your help; thank you very much). Enjoying the constant pressure from the CSV1A!
Valveman was not suggesting removing the check valve at the pump, but rather to add the check valve indoors as a temporizing measure.I guess I should have had the well guy remove the check valve on the pump so I could install one before the CSV -- which (if I am thinking this through correctly) would "fix" the leak and do so without the water hammer. True?
No!can I then remove the check valve at the pump thus avoiding the water hammer potential
