I have successfully replaced the pressure switch on the well water system at the family cabin with help from here. Thank you!
However, the pump cycles on and off rapidly when using water (like filling a sink to do dishes), and I am suspecting that the Jacuzzi Hydrocel (which I believe acts as some kind of pressure vessel) may be bad (its only been there since the 1970s). Am I correct what it does in the system? Can I replace it with a bladder-type pressure tank to prevent the pump from cycling so often when using water from the system? A one-for-one exchange? How big a pressure tank do I need? The family cabin is five hours one way, so I'd like to make sure I take up all the parts I need and that they are the correct ones. Thanks in advance.
