Replacing a Bathtub with Washer and Dryer
GoodMikeT
Levittown, Pennsylvania
I am remodeling my upstairs bath and replacing the bathtub wit a washer and dryer. I plan on using the existing tub drain to connect to a washer pan. The following pic is the current config.
Can I connect the standpipe drain line to the 3" vent using a wye fitting?
Smooky
North Carolina
What are you going to do with the existing tub and the shower drains? Do you plan to cut out and repair that section of pipe?
quote; How about this way;
The "new way" looks exactly like the old way. The pipes just go in a different direction. And the connection to the system is still too low.
GoodMikeT
Does this look any better? In this example I would remove the existing bath/shower trap and cap the line. The new washer pan would have an open drain to the outside.
Smooky
North Carolina
GoodMikeT
I would cut out the section where the toilet and tub tied into the 3” drain line. You need to come up and tie the vents together at 42 inches above the floor or the minimum height would be 6” above the flood rim of fixtures on this floor.
I can definitely cut out and cap the tub drain but I will be installing a new toilet in the current flange location.
Smooky
North Carolina
In the above diagram the washer is vented but the toilet is not. The little extra “L” part is not doing anything the way you have it there. You cannot wet vent a toilet with a washer. The washer waste should enter the 3” pipe below the toilet drain.
Do you have access to the drain pipe below where the toilet ties into the 3” pipe?
GoodMikeT
I removed some more sub floor to get better access. The first pic is a san-t installed below the san-t for the toilet. The second pic is a 3x3x3 san-t with a 2" inlet. The 1 1/2" pipe from the tub will be cut off and capped in both instances. would either of these options work?
k?
Smooky
North Carolina
I agree with cwhyu2. The top picture is about what you need. The drain fitting below the sani-tee from the toilet should be a wye instead of another sani-tee. You are almost there.
GoodMikeT
Before I start cutting pipes, I am curious as to whether I can connect the washer drain to the two inch waste/vent pipe in the pic below (left side). The bathroom sink drains into this pipe. it is also a wet vent for the sink in the bathroom below.
