Long time follower first time poster.
Wife and I purchased a home built in 1938. Will work over the next year or so to remodel the vast majority of the home.
Little background to explain how we ended up where we are.
We have a bath that needs replacement handles. Both sides were leaking and the cold had a constant drip. Got them apart, cleaned everything well. New washer and cold no longer leaks/drips. Also got the stems to stop leaking by using teflon tape on all threads combined with a light coat of rector t plus 2. I have never seen a set of stems like these so dug in cautiously. Assumed there was a rubber oring or washer that had just totally rotted. My lucky week so far.
Looking to replace the handles as they all three are stripped and the threaded compression sleeves are broken off and will not stay on the stem. Previous owner looks to have used some sort of glue on them which caused the threaded sleeves to break off when I was working them off. We are remodeling the bath in the next 6 months or so but cant find these type handles to save my rear.
The hot stem will take a handle that can screw through the end of handle. Not sure if you can see but the cold side is not drilled and tapped on the end. So not sure what else would work outside of the splined compression handle n that one.
Any budget fixes for these? Or cheap replacement handles. Dont care what they look like just so the work as bath will be gutted come winter. Could glue them again but trying to avoid anything permanent'ish in the event I have to tear into them again between now and when we remodel.
Thank you in advance for any and all help. Stay safe.
Brad
Brad
