OK I just moved my well tank and replaced it with another bladder tank of the same size.
I moved the tank to within 3 ft of the inlet from the well coming through the basement wall. The old tank was about 25ft across the basement where a previous pipe came through from across the street. Old farmstead with a well house now split into two properties.
I installed a check valve between the black tube coming from the well and the T on the well tank. This is the only difference from the previous system other than it looks much nicer and cleaner!
When the water pressure drops, the switch clicks and it takes a couple seconds then the pump kicks on, the gauge jumps a bit then pumps as normal. Takes about a minute to hit 50 psi. Could the check valve be causing this weird startup?
Pump is a 2 wire and seems to be working fine.
Also would a new tank make the water smell from the rubber bladder for a few days?
Thanks so much,
Phil
Thanks so much,
Phil
