Piperca
I'm repiping my house with pex next month. It's a small job, two bathrooms and a kitchen, which all share the same plumbing chase. Access will be great, as I'm remodeling one of the bathrooms at the same time, which will give me almost full access to the chase. My Intention is to cut the existing copper close to each sink/toilet/shower, add a fitting to accept the pex, then run directly from a Viega manifold with pex to make the connection.
Last evening, our gas water heater failed, forcing me to replace it ahead of the repipe. I noticed there is a bonding wire on the cold inlet to the water heater. I was intending on running pex from the copper plumbing in my garage to the water heater. If I do that, what should I do with the bonding wire? Move it to where the copper/pex join in the garage? Any input would be greatly appreciated. Thanks in advance.
