NickB84
Hello all, this is my first post, so my apologies ahead of time....
I have a Repco GMT110 gas fired boiler for baseboard heating. I currently have a pressure issue with the boiler hovering around 30 psi due to relief valve holding it there. I believe I have narrowed down to a leak in the tankless coil, thanks to other threads here and elsewhere (ruled out expansion tank, don't have auto fill valve, aquastat is working and no high temp).
I would like to replace it, however, I have no manual, and I think Repco is out of business so long, I can't find anything online. I am considering switching to an indirect setup, but can't afford to switch right now financially or with the current weather, so I'm just looking to get back up and running quick and cheap.
The coil is a 6 bolt hole, 7 1/4 or 7 1/2 diameter (will take another measurement to confirm) round coil with the well for the aquastat as well as a port for the T/P gauge. I have seen both sizes online, but without the manual, I don't know the GPM of the current coil, which I'm guessing would drive the length and whether or not it would fit in my boiler. I also have not seen one that has both the well and the gauge port.
Any help is very much appreciated. Don't really want to keep running the boiler in this state, but don't want to pay a fortune to have someone replace a coil I can replace if I can find one.
Thanks,
Nick
Another quick thought, also considering abandoning the tankless coil altogether and installing a hot water heater instead. Since its leaking I would have to cap it I think. Considering adding a relief valve there too, just in case the leak became obstructed.
Think it would be nice to secure the boiler in the summer months, however, I've read that boilers may leak if they've never been cold.
Appreciate any thoughts on that as well.
Thanks,
Nick
