Mark Gendron
Good afternoon,
I am having some difficulty replacing some pool plumbing. I need to run a new 1-1/2" schedule 40 PVC connection between the pump outlet and the selector valve. Unfortunately, a previous technician installed a schedule 80 pipe nipple into the inlet side of the selector valve. Either the pipe nipple was overtightened, or it was installed with a hardening cement. Or both.
I tried to cut out the pipe nipple, but it isn't going to budge. Even where I have broken away pieces of the pipe nipple, its threads have been left behind.
I am looking for suggestions on how I might approach this repair, without having to spend hundreds of dollars to replace the selector valve! One possibility that comes to mind is to use an appropriately-sized hole saw to remove the remainder of the pipe nipple and the damaged threads, and then cement in a street fitting with female threads, or a straight piece of 1-1/2 PVC with a union attached, or some variant thereof.
I look forward to your suggestions!
Thanks,
-Mark
Thanks,
-Mark
