Yodasfather
Good day,
I have an EC4 twin tank 50000 installed 2013. Paid 4K with the ultrfiner ii ro system. I’m on city water with hardness of 12, no iron, 3 ppm chlorine. I have never had a problem with the unit. I have also never had the unit “serviced”. For some reason, Last week I decided I needed to clean the resin tank, which I had never done.
My problems started right after I added the salt back to brine tank and did a manual regen. The brine filled up with water and never went down. It also started leaking from somewhere above the injector. Water seems to running in the unit non stop (I could hear is in the head, but brine tank did not continue to rise. I just bypassed the unit to quit wasting water.
My questions are, should I call Rainsoft, or should I replaced the unit? The reason I ask is because, since I never had it serviced, will Rainsoft refuse to honor the Lifetime Warranty? Will I need to replace the resin beads soon, is a RAINSOFT service call going to be so expensive I could get a new Fleck 5600 or o e of the more efficient u it’s that uses less salt and water?
Rainsoft quoted my 280 to replace filters on the RO system so I just bought a new Homemaster Artesian for 400. The Homemaster is supposed to be approximately 1 to 1 waste.
Thanks for any advice.
