Hello All,
New to this site. Great discussions here!! I live in Henderson NV, right next to Las Vegas. I had a [** Edit ** from 9100 to 9000 as I have a brass, not plastic valve] Fleck 9000 (non digital) system installed when we moved here 10 years ago. In the past couple of months, I have noticed more scale in the dishwasher and on some of the bathroom shower doors (looking closely). Did some simple hardness tests, comparing the outside faucet water and kitchen/bathroom water and see no difference in hardness. I have ordered some test kits off of Amazon, but I have started to look at the softener.
Read the manual, forums, videos, etc. What I immediately see are a few things:
1. Valves are leaking a small amount of water during the regeneration session after starting a manual regen. Read on here, that is time to do a rebuild with a rebuild kit.
2. However, watching the total process, I do not see any brine moving from the brine tank to the resin tank(s) during the regen process. It "sounds" as if there is suction happening, just do not see water moving down in the brine tank.
3. I see the control valve pointers (which cycle it is on, which tank it is on) moving as expected.
The amount of water seeping at the valves is VERY small. I assume this is not a huge problem, but should get the unit rebuilt -- if I choose to go this path. The brine issue is another story. Could this be as simple as cleaning out the brine tank, inspect/clean brine lines/valve in brine tank, and take apart and clean/replace the brine line between the brine tank and the valve??
I probably could do this myself, but am open to give the service business to someone, but I don't know anyone in this vertical within the LV market. I see other long-time posters recommending other businesses on this forum -- any for the Henderson/Las Vegas market that could work on a fleck unit, recommend a new solution if I go that route)?
Thanks in advance for any help!!!
