Bert Lee
I want to replace an outdoor which would normally be a very straightforward homeowner job for me but when I looked at what's there and what I'd need I was reminded that the entire sill had been nicely spray foam insulated and the current valve, connection and part of the feed pipe and well covered in that insulation. And its a fairly tight corner space with a floor joist in close proximity so while there's some room there isn't a whole lot to maneuver in. I know that the mechanical removal is one option with chisels, blades and brushes but was curious if there were any other less tool and time intensive options to consider. I'd imagine this gets seen a lot by the pros.
Thank you,
Thank you,
