Removing sharp texture from wall
Pickngrin
Massachusetts
Hi-
I've got very sharp texture (my wife once cut herself on it) on both sides of the stairs leading down to my basement. What would be a reasonable way for me to remove this? Wet it, scrape it off, and 1/4" drywall over it? Or drywall over it without scraping? Skim coat? Something else? It is a small area.
Thanks,
PnG
It depends on what they actually used for texturing, and if they put a coat of paint over it. Stuff like ceiling texture will usually soften if you wet it, and then, it's fairly easy to scrape off if it wasn't painted over. If they used a cement based stucco material, wetting won't do much of anything.
Should you try to sand it off, make sure to wear LOTS of protection for both your body, especially eyes, and lungs, as some of the stuff could contain silicon, and that can be carcinogenic in dust form. Regardless, it will make a mess, so dust collection is mandatory and cleanup will be a pain.
I'd see if it softens when wetted, and then, scraping it off is fairly easy. I did the ceilings of about 500sq in a few hours by using that method. I couldn't do that today as I am a lot stiffer, and working over my head isn't a real choice. On a wall, though, shouldn't be an issue if it softens when wetted. Using a spray bottle, get a section really wet, then wait maybe 10-minutes...you'll know by then if it can be scraped off.
1/4" drywall will follow some of the peaks and valleys of the texturing...IOW, it will be hard to keep it nice and flat. 3/8 or 1/2" would have a better chance should you decide to cover it up.
Or, if it was done over drywall, you could tear the old stuff out and put up new then paint it easily...maybe less work, but you'd have more stuff to cart to the dump. Drywall is pretty cheap. How much is your time worth?
Pickngrin
Massachusetts
Thank you for this. I like the idea of trying to scrape first. It is not a lot of square footage, but I know that it will be a mess. The value of my time has changed as a function of the pandemic, but there are still other ways I would prefer to spend my time. Your comment about the 1/4" drywall is helpful and I had some doubts about that as well.
