SmdCarpenter
Hello all,
Looking for some ideas on how to remove sand from my 32' deep dug well, it is 36" wide with 2' concrete rings stacked over one another to form it,
The water comes through weep holes at what appears to be 27' deep , unfortunately after 60 years I have accumulated sand that has left my current well bottom at 28' so I only have 1' of water...not enough to run the submersible pump I have as the motor would be embedded in mud.
Is it worth hooking up a spare shallow well pump I have setting its pipe halfway through the 1' of water leaving 6" of water below the pipe and hoping it can pull the 27' lift (I'm basically at sea level) and being super careful with usage as a temporary solution?
With it only being 36" wide once I put a ladder down the well there isn't really much room to shovel after maneuvering around the ladder, plus it is dangerous in a variety of ways and I hear air supply would be an issue and I don't have readily available help to haul the buckets up.
