Removing QD Pumptec
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Do any of you guys know if the control box will still work if you remove the QD Pumptec from inside it? Will there need to be a jumper?
Craigpump
Yep, but why would you remove the PumpTek? Just have to put the L1 & L2 lines on the proper pins.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Apparently the Pumptec will not work with the low amps created by the CSV. So he is removing the Pumptec and installing a Cycle Sensor. Just never pulled a pumptec out of the box before so thanks Reach.
