John JG
I live in a 5 unit condo and we share the hot water heater with a circulating pump. The return line is made up of type M copper ( the thinnest type) and is under the slab foundation. When there is a pin pole leak on the return line, we need to jack hammer under the slab to access the leak. The recirculation system is very problematic. Is there a way to remove the return line under the slab or just not use the return line/pump all together? The pump is currently broken, unplugged, and every unit still gets hot water, so there is really no need for a recirculation system.
