Remove Sink Legs
DG624
Columbus, Ohio
I have an American Standard sink from 1952 but I don't like the legs and towel racks. Can I remove them without weakening the attachment to the wall?
DG624
Columbus, Ohio
If I strengthen the attachment with more bolts will that be enough? The sink is not cast iron so it is probably half the weight.
Because the sink has legs, the actual connection and blocking in the wall may not be all that great, so, adding bolts may not help much. The house I grew up in had that same sink. When I went to remodel, I found that the wood blocking in the wall had shrunk, the attachments of the blocking would allow the sink to flex the blocking, so without the legs, it was unstable and no longer could stay tight to the wall. But, you won't know unless you try. If you tighten the bolts too much, you could crack things. Ours was an American Standard product, but it looks like your picture. I ended up replacing the sink, since ours was blue, and it wouldn't have fit in any longer with the new shower, etc.
DG624
Columbus, Ohio
I called American Standard and received an affirmative reply when I asked if I could go without legs...but I have not been able to give them and exact model number. I think I can strengthen the attachment by creating more bolt hole attachments at the rear but I would have to drill two openings.
I spent some time polishing this sink and it does look very nice but it may have been in vain if I can't use it. When the sink is removed for painting I will check the wall support.
Thank you for the reply.
