Remove leaking lever bathtub handle
Discussion in 'Shower & Bathtub Forum & Blog' started by brad4000, Sep 16, 2018.
  1. brad4000
    brad4000 New Member
    Sep 16, 2018
    Huntington, WV
    Hello,
    Thanks for any help. The faucet in my bathtub is leaking, recently getting worse. I've changed out washers on sinks before to stop it, and plan to do the same here. The only problem is I can't see how to remove the handles to get at the cartridge inside. No discernible set screws. No brand name readily visible. I was tempted to just pull on it, but didn't want to create any new problems. I've attached two pictures, one from above and one straight on. Thank for any help or advice!
    [​IMG]
    [​IMG]
    https://drive.google.com/open?id=1jznpmpIsCU-g14AEDtWimW3WlM6TNlmX
    https://drive.google.com/open?id=1sQKXrQF0-dJaAZ5ReRWWdeCYllCk2lIo
  2. jadnashua
    The small dome on the outside of the handle probably pops off to expose a screw underneath it. Be careful what you pry with so that you don't scratch the finish. Look carefully from the side, and you'll probably see that it is a separate part. If you know the brand, you may be able to find the manual online which would identify both how it goes together and the required repair parts.
  4. hj
    That is a Delta diverter spout, which means that 90% of the time it would be Delta valve. They use set screws in the side of the handle to secure it.
Similar Threads: Remove leaking
Shower & Bathtub Forum & Blog Sayco shower leaking - cannot remove handles Jul 10, 2011
Shower & Bathtub Forum & Blog Leaking Diverter - Can't remove May 7, 2008
Shower & Bathtub Forum & Blog Remove cartridge holding nut inside Sigma shower assembly Thursday at 10:38 PM
Shower & Bathtub Forum & Blog Single Handle Shower Set Screw Broken Can't remove handle Jan 28, 2019
Shower & Bathtub Forum & Blog How do you remove old Grohe shower handle Aug 10, 2018
