Remote dishwasher installation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pdklein88, Nov 25, 2017.
  1. pdklein88
    pdklein88 New Member
    Nov 25, 2017
    Michigan
    Hi,
    I'm looking for advice on how to install my dishwasher. Due to the layout of my kitchen, I am unable to install it next to the sink. Therefore, I am wondering if the attached image would be an acceptable way to install the waste water plumbing?
    I would create a high-loop behind the dishwasher, run that down through the floor to a P-Trap, and over (sloped) about 10 feet to connect into the existing sewer line with a "T".
    Thanks in advance!
  2. pdklein88
    Nov 25, 2017
    Michigan
    This would be the view from above, assuming you could see through the floor.
  4. jadnashua
    If you give it its own trap, that trap needs to be vented. What I did with mine is to run a drain line underneath the cabinets and then came up into the sink base to the garbage disposer. Some places require an air gap (safer way anywhere). Hard piping it to the drain system has the potential, if there's a blockage, to get sewage into the DW, and you might not notice once it drained, leaving you with a very unsanitary situation.
  5. dj2
    dj2 In the Trades
    Aug 13, 2013
    California
    You have to follow your city building code. Your code will specify if you need an air gap or if you can use a high loop. DWs have a built in high loops (on the side), but you may need a high loop under the sink.
    I can only tell you that in my city an air gap is required, and in that case no separate dish washer trap and vent is needed. The DW waste goes to the air gap, then into the garbage disposer and the trapped/vented drain under the sink, OR directly into the trapped/vented drain under the sink (if you don't have a garbage disposer).
    The DW can be 10 feet away from the sink. You will have to find a long enough waste hose as DWs come with short waste hoses.
Similar Threads: Remote dishwasher
Plumbing Forum, Professional & DIY Advice Pipe size and recommendations- remote manifold w/ recirc-tri level w/stacked baths/laundry Jul 3, 2021
Plumbing Forum, Professional & DIY Advice Delta R11000 pfs px ws flow rate to remote hand held Nov 10, 2020
Plumbing Forum, Professional & DIY Advice Remote operated (reach rod) drain valve? Sep 9, 2020
Plumbing Forum, Professional & DIY Advice Suggestions for remote solar powered water pump Oct 24, 2019
Plumbing Forum, Professional & DIY Advice Remote thermostat for electric water heater. Aug 23, 2019
