Remodel laundry room - washer and sink vent stack?
Discussion in 'UPC Plumbing Code Questions' started by Murphyd, Sep 5, 2019.
  1. Murphyd
    Murphyd New Member
    Sep 5, 2019
    Austin, TX
    I have read most of the posts on adding sink to laundry room and believe I have correct but wanted to make sure I meet UPC 2015 code for drain and vent stack. Here is picture I found and adapted for my remodel.
    Moving washer to the right and adding sink to where washer was located. Single story, stack vented thru roof.
    Thanks in advance...
    Laundry_Room_Remodel.gif picture I
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Looks good.
  4. Murphyd
    Murphyd New Member
    Sep 5, 2019
    Austin, TX
    Thanks for quick answer, appreciate the advise.
  5. Terry
    Aug 17, 2004
    804.1 All plumbing fixtures or other receptors
    receiving the discharge of indirect waste pipes shall be
    approved for the use proposed and shall be of such
    shape and capacity as to prevent splashing or flooding
    and shall be located where they are readily accessible
    for inspection and cleaning. No standpipe receptor for
    any clothes washer shall extend more than thirty (30)
    inches (762 mm), nor less than eighteen (18) inches
    (457 mm) above its trap. No trap for any clothes
    washer standpipe receptor shall be installed below the
    floor, but shall be roughed in not less than six (6)
    inches (152 mm) and not more than eighteen (18)
    inches (457 mm) above the floor.
Similar Threads: Remodel laundry
UPC Plumbing Code Questions Laundry Room Remodel Using Existing Vent Aug 5, 2011
UPC Plumbing Code Questions Remodel wall hung toilet Jun 3, 2014
UPC Plumbing Code Questions remodeling and want to make a change to my drain lines May 20, 2014
UPC Plumbing Code Questions Proposed drain and vent for bathroom remodel, UPC Jul 5, 2010
UPC Plumbing Code Questions Laundry trap height, water main line vs meter size, AAV Aug 1, 2018
