Hello! I want to relocate my washer. I’m on a slab foundation, and want to relocate drain 16’ away from existing drain and vent, but would like to use the existing drain and vent. This is on the same wall just moved 16’ away. Can I do this? I’ve thought of different ways this could be done. One way I thought would be cutting the existing drain pipe about 4 inches above the floor and 90 out from wall, then 90 over to run length of wall to new stand pipe with my 1/4 “ slope per foot. This would eliminate having to drill through the wall studs, and I could hide 2” drain pipe behind cabinets.
The other Way would be to cut through studs, and run behind wall, just not sure what that would do structurally. Also wonder about the vent, can I tie into the existing vent 16’ away?
