Reliance 310C transfer switch circuit not working
vdotmatrix
Virginia
I installed a Reliance 310C transfer switch which has in the A&B position a double pole breaker which I replaced with (2) 20a breakers to use as separate circuits through the main load panel .
BUT, when I replace these breakers, the A circuit, which powers the Frig, will not energize. all the other circuits light up like a charm....
I replaced the breaker on the main load panel...I think there is a problem in the transfer switch .
Any ideas?
Would have to see a wiring diagram for the switch.
Are you tying to run off a generator ?
Good Luck.
I called reliance and they instructed me to open the switch compartment to fiddle with the switch and when i did i saw the issue, red wire got pulled and and switch wasn't wired -all is well now..... thanks
I like a simple fix. :)
Enjoy.
That is something we could have NEVER have diagnosed without being there.
I would have had it apart to take a Look See.
A lot of stuff is assembled in a piss poor manner. It does not hurt to check their work.
I void the warranty ASAP to do a QC check. Some stuff should have never left the factory. :eek:
