Randy Edge
I'm in Florida and have a drain question. I'm finishing out the inside of a detached workshop. In the 'she cave' side, there will be a sink base with a standard kitchen sink. The drain in the slab is 2". The framed walls are 2" x 4". I know at some point it will have to be reduced.
The drain didn't turn up in the right spot for the sink, so I will have to run over through the wall about 4' to get to where the sink will be.
Will I violate any codes by reducing where it stubs through the floor? Or should I get it to the sink and then reduce?
It doesn't really matter to me other than when I hole saw a 2" through the wood there won't be much left on each side of the hole. Thanks.
