opto_isolator
After much discussion here - I ordered a 2 cu ft unit due to the size of our house, as well as for future considerations (I don't want to have to buy a new resin tank to keep up with the SFR). I measured the water in our neighborhood and it came out to 12 grains (previously, I had measured the water in the house we were staying - which is only 5 miles away from our new house, but in a different city). There is 0 iron. This will be sized for 3 people. Based on calculations on Gary's web site he shows a total hardness capacity of 17,280. Based on his chart, it looks like I can use 5 lbs of salt per cu ft of resin - to reach 18,200. If I set the softener to 32k (which would be 1 cu ft), it should be 5 lbs of salt every 8 days. We wouldn't be using up the entire capacity of the 2 cu ft of resin, understandably, but will have enough for future capacity. I ordered from Ohiopurewater, good price - got the top basket and gravel bed. What settings should I set when the unit arrives? I copied the defaults from what I saw, and made changes to the "C," "H," and "DO" settings - but nothing else. Can anyone recommend what if any changes I should make from the defaults?
DF: GAL
VT: St2b (Standard Downflow/Upflow Double Backwash)
CT: Fd (Meter Flow Delayed)
C: 32k (capacity)
H: 12 (hardness)
RS: SF (Percentage Safety Factor)
SF: 20 percent
DO: 8 (Day override)
RT: 2:00AM
BW: 10 mins (back wash)
BD: 60 mins (brine draw)
BD: 40 (salt time setting)
RR: 10 mins (rapid rinse)
BF: 10 mins
FM: t1.2 - 1.5'' Turbine Meter (7000 default)
DF: GAL
C: 32k (capacity)
H: 12 (hardness)
SF: 20 percent
RT: 2:00AM
BF: 10 mins
