Recommendations for iron treatment 7.4ppm. Filox, Katalox lite?
JoshSter
MN
Hello -I'm looking for recommendations on treatment for well water with high iron.
Well output: 9.5 gpm
Laboratory test results:
Hardness: 25 gpg
Iron: 7.4 mg/l
Manganese: .345 mg/l
PH: 7.5
Tannins: .5 mg/l
TDS: 373 mg/l
I am replacing a 1.5 cf greensand filter that never really worked well. It never took care of 100% of the iron and smell in the water. It's 8 years old now.
I already have a 2.5 cf softener I use after that which is still working well.
So far most of the recommendations I have gotten include chlorination followed by a retention tank then a 1.0 cf pro-ox/filox or 2.0cf katalox lite. Is one of these better than the other for these conditions?
Are there any other options I should be looking at. Any advice would be appreciated. Thank You!
The gpm available for backwashing becomes important for both of those.
I have not checked, but I would think the backwashing gpm for 8 inch diameter filox may be similar to 12 inch KL. Filox is heavy. Looks like about 10 to 12 gpm for the KL I would think. Anyway, no sense considering ideas that your pump won't do.
That said, there are controllers that can deliver the higher backwash with water from the pressure tank. To do that, they can backwash in time segments. The pressure tank may not have enough water to begin with, but after the first, the pressure tank will be full up and ready to deliver high flow water for the upcoming segment(s).
index.php
index.php
Do add drain valve after the contact tank and after the media tank. This lets you measure residual chlorine. I don't know how effective KL is in removing chlorine or H2O2, which is an alternative for injection instead of chlorine.
For injection, you can have proportional injection pumps that vary the rate of injection to match the flow. That is the better way. With a fixed-rate pump, you need to inject before the pressure tank, and that precipitates stuff in the pressure tank.
Do you know any specific controllers off hand with this capability?
XTR2, such as on the Fleck 5810XTR2.
That is the one I know.
Typically a pressure tank holds about 1/4 of the nominal capacity.
JoshSter
MN
Ok. Are you saying that the 1.0 cf pro-ox/filox or 2.0cf katalox lite are unlikely to work with the well pump capacity, or there are more options if I use a controller with the time segment capability? Most places that sell Katalox Lite say 5 or 7 GPM backwash for a 12" tank diameter and 7 GPM for Filox in an 8" diameter tank.
Would I be better off getting 2 1.0cf katalox tanks in parallel and regen them on different days?
Check https://www.watchwater.de/katalox-light-iron-manganese-and-hydrogen-sulfide-removal/ including the brochure. That is the manufacturer. Note that until the brochure, backwash water temperature is not taken into a account. The first page says 10 to 12 gpm per sqft is enough for backwash. That seems maybe ok in cold places, but I think it would be significantly below optimum in California. Even in MN, 12 gpm/sqft seems low when you work through the bed expansion graph, but may be adequate. I am not a pro. I just worked through the numbers.
Most systems don't backwash in segments, so the backwash they can do is pump-limited.
ditttohead
Water systems designer, R&D
Ontario California
Check out RO tanks instead of well pump tanks, these typically have twice the capacity of a well tank since they are basically the same but with a much larger bladder. Also, drop the pressure in the tank to 5-10 PSI of air pressure. Not recommended on well tanks since it will stretch the internal bladders.
ditttohead
Ontario California
Katalox Light with an RO pressure tank... use the Vortech tank which will help. H2o2 injection instead of chlorine, controlled injection with a meter is critical.
